Cheeser64
Sep 06, 2020Aspirant
AX4200 or AX6000 - dual wan capable?
Do either of these new devices support dual wan connections? I have Comcast as the primary, with centurylink as my current backup. I looked at the specs and user manuals, but didn't see this.
Cheeser64
FURRYe38 wrote:Having separate dedicated WAN ports on Orbi, then no.
If so, that's a shame...especially for the price. I have a Netgear cable modem, but a different DSL modem (Zyxel). I only had one provider in the past to our home, but with more work done from home, need the redundancy.
i could probably still consider these, but then could only use as access points.
Sep 06, 2020Guru - Experienced User
Well these are home class products, thus meant really for home users with just 1 ISP service and modem/ONT.
Most dual WAN users are in the business realm and may see more use in those envronments. Something you might check and see with the Orbi Pro version doesn't this. IT was announced they were doing a Orbi AX pro version.
- Cheeser64Sep 06, 2020AspirantUnderstood, will check the pro version.
More consumer products seem to be including dual wans, thus I thought I would check.
