hockeyboy's avatar
hockeyboy
Follower
Jul 18, 2020
ax4200 placement and direction
Just installed the AX4200 - does anyone have a suggestion for how far off the floor and what angle or direct I should point it if its against an outside wall???
1 Reply
  • FURRYe38's avatar
    30 feet is recommended starting distance between the RBR and RBS, as the crow flies in any direction, between the RBR and RBS. Farther distance is also possible. Depends on building materials as well.
    ttps://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
    The RBS and RBS are onmi directional so pointing them should work either way you face them at each other or not.
