DJ1964's avatar
DJ1964
Guide
Apr 28, 2020
AX4200 QOS for Ringcentral Viop phone
Hi, I've been using the Orbi for a couple weeks with great results from a bandwith and coverage standpoint.  Today, I wanted to set up my Ringcentral Cisco viop phone for my job, and I've been able t...
  • FURRYe38's avatar
    Apr 28, 2020
    Orbi's QoS is behind the scenes and automatic. Even on Orbi AC. So you'll only see the speed test app listed under QoS.
    Unless your having problems, you should be fine with the phone working thru orbi. Most phone IP services don't use much bandwidth unlike video streaming or some gaming services. Voice is a low bandwidth medium.
