TyneBridges
Mar 03, 2021Tutor
AX4200 (RBK752) - STILL stock issues
Does anybody know why availability should still be a problem, months after the product was released? This Orbi system is even more expensive in the UK than the US. Practically every retailer shows it...
schumaku
Mar 03, 2021Guru - Experienced User
Manufacturing is still hit by Covid impact - even expensive business class materials are massively delayed. Nothing Netgear specific.
https://store.netgear.co.uk/product/rbs750-100eus shows two in stock as of writing - so hurry if you need add-on satellites.
Here in Central Europe, all RBK75x and RBK85x kits are readily available from the distributors, except of the RBK752. Pricing looks slightly more attractive than in the UK. Keep in mind your VAT (typically not included in the US prices) is extremely high.
Please be aware the US/FCC variants are locked to FCC regulatory settings AFAIK, while the -100EUS the correct one.
TyneBridges
Mar 03, 2021Tutor
Thanks Schumaku. Unfortunately I need the router as well, so I guess I'll have to wait.
- schumakuMar 04, 2021Guru - Experienced User
TyneBridges you might want to challenge uksales@netgear.com FMI ref. availability.
