TyneBridges
Mar 03, 2021Tutor
AX4200 (RBK752) - STILL stock issues
Does anybody know why availability should still be a problem, months after the product was released? This Orbi system is even more expensive in the UK than the US. Practically every retailer shows it...
TyneBridges
Mar 03, 2021Tutor
Thanks Schumaku. Unfortunately I need the router as well, so I guess I'll have to wait.
schumaku
Mar 04, 2021Guru - Experienced User
TyneBridges you might want to challenge uksales@netgear.com FMI ref. availability.
