zbamboozler
May 14, 2021Follower
AX4200 RBR750 and RBS750 downloading half the speed
Recently bought orbi to run a satelite from my room for my PC. With our old charter spectrum router we got steady 200 download speed. Since connecting to orbi we are getting 70-100 speeds. Is this no...
May 15, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Armor, Traffic Meter, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s).
- kolellaMay 15, 2021Apprentice
Have you checked your lan cables? Are they minimum cat 5e? Go to Attvanced and select "show statistics" what do you see? here is an example of a router and satellite connected with wired backhaul
