Hubba_Bubba
Mar 23, 2021Star
AX4200 RBS750 satellite blocking Internet
I use Spectrum, using an Arris modem/router where I had previously eliminated any potential use of it as a Wi-Fi router, and also eliminated any potential for a dual-Nat situation on my previous Orbi...
Mar 23, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Does swapping RBS locations with the other continue to follow with the 2nd RBS?
- Hubba_BubbaMar 23, 2021Star
FURRYe38 wrote:What Firmware version is currently loaded? V3.2.16.22_1.4.9
What is the size of your home? Sq Ft? 4000 sq.ft
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. Straight line approx. 42' for one and 32' for the other. This is not an issue as when the "problem" satellite was the furthest distance, it exhibited the same problem as when it was at the shortest distance.Does swapping RBS locations with the other continue to follow with the 2nd RBS? I have no idea what you are asking.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.Does swapping RBS locations with the other continue to follow with the 2nd RBS?
- FURRYe38Mar 23, 2021Guru - Experienced User
Turn OFF both RBS then swap locations with each other. Power ON the 2nd RBS that you swapped around. Leave the other RBS OFF. Test the connection thru this 1 RBS...Does it still exhibit the problem with different devices?
