IcedCorn
Apr 22, 2020Tutor
AX4200 Thoughts
I know this unit is new since it's not even in the drop down but , anyway, I have been using the AX4200 for 2 days and tried to just keep what I could from my old RBR50 setup (This is the RBR750 btw)...
Apr 23, 2020Guru - Experienced User
Thanks for your posting and information.
What others are seeing:
https://community.netgear.com/t5/Orbi-AX/Missing-tile-for-security-on-orbi-app/m-p/1898755#M3092
https://community.netgear.com/t5/Orbi-AX/AX4200-vs-AX6000/td-p/1889701/jump-to/first-unread-message
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Just curious, why do you have NAT Filter set to OPEN and ALG disabled?
- IcedCornApr 25, 2020Tutor
My understanding is that for the best console game experience you need NAT open. In addition SIP ALG isn't needed for most homes.
But: 1) I'm not a network guru. 2) I may be wrong.
- FURRYe38Apr 26, 2020Guru - Experienced User
Yes and SIP shouldn't interfer with home configurations.
