Jimanator
Apr 14, 2020Guide
AX4200 versus AC3000
I just ordered an AX4200. I've been using an AC3000 for a few years. I recently upgraded to ATT fiber and expect I will see an overall improvement in WIFI speed with the AX4200 (ATT fiber is up to ...
Jimanator
Apr 14, 2020Guide
Home size = 3700 sq.ft.
Modem is an ATTU-verse, model 5368AC
Apr 14, 2020Guru - Experienced User
Your modem already has a built in router. What mode is it working in currently? When you get the Orbi system in, its recommended to bridge or use the DMZ/IP Pass thru on the modem for the Orbi router if you want to use the Orbi as a router.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Some historical reading on ATT modems:
https://community.netgear.com/t5/Orbi/Installing-Orbi-behind-ATT-Pace-5268AC-gateway/td-p/1234191
https://community.netgear.com/t5/Orbi/Netgear-Orbi-and-ATT-Pace-5268-Router/m-p/1786833/highlight/true#M68004
https://community.netgear.com/t5/Orbi/ATT-fiber-BGW210-and-costco-RBR50-RBS50/m-p/1868313#M83488
Modem FW may have broke good speeds between the modem and Orbi in router mode:
https://community.netgear.com/t5/Orbi/RBK50-Speed-Throttling-Wired-and-Wireless/td-p/1673291/jump-to/first-unread-message
- JimanatorApr 14, 2020Guide
I'm already using he Orbi system with the ATT router. My only change would be going from an Orbi AC3000 to an AX4200. I was just asking about the performance between the two units.
- BanditoApr 14, 2020Luminary
In my experience, you'll see no improvement in the performance of your existing AC clients, but can see a bit of a performance boost with any WiFi 6 clients that you may have. So, overall, you'll see little change in your wireless network performance.
- FURRYe38Apr 15, 2020Guru - Experienced User
Just checking the mode on your Modem. It already has a built in router. Having two routers on the same line can be problematic.
Good Luck.
