sshams5895
Apr 08, 2020Tutor
AX4200 vs AX6000
Looking to upgrade to Orbi Wifi 6 Mesh system. Our house is about 3,000 square feet. 45-50 devices roughly. Family of 6. I have trouble getting a good signal in my garage where I work out and lik...
- Apr 22, 2020
Been using this for over a week now and performance is good. Not sure what I am missing out on by not spending the extra $200. We have 6 poeple in this house, over 40+ devices with kids streaming all the time. And my AppleTV in my garage works just fine while I work out. So what I don't know won't hurt me, I guess.
Overall, I am happy with the 4200.
farmrt88
Apr 09, 2020Star
In addition to the 2.4GHZ difference, the 5GHZ fronthaul band is only 1200Mbps on the RBK 752 AX4200. The 5GHZ fronthaul may only be a 2X2 radio vs the 4X4 on the RBK 842/852. There are also 2 less antennnas and a slower processor on the AX4200. The important backhaul speed remains the same at 2400Mbps.
It's nice that early adopters still have the highest performance WIFI 6 Orbi for now, similar to the RBK50/40/20 rollouts. Hopefully this continues.....
2.4GHz (600Mbps†) + 5GHz (1200Mbps†) for WiFi devices to connect to the Internet5GHz (2400Mbps†) dedicated WiFi link for faster data connections between Orbi Router and Orbi Satellite
2.4GHz (1200Mbps†) + 5GHz (2400Mbps†) for WiFi devices to connect to the Internet5GHz (2400Mbps†) dedicated WiFi link for faster data connections between Orbi Router and Orbi Satellite
Apr 09, 2020Guru - Experienced User
Its nice to have some flexible products out there that are a bit cheaper. One doesn't always have to have the higher performer. LOL.
At leaset this gets some in to the AX realm for there needs.
Thanks for posting.
- sshams5895Apr 09, 2020Tutor
Very helpful posts. Thank you.
The AX4200 is on its way tomorrow and I'll check it out and see if it works best for our household.
Thank you.
- FURRYe38Apr 09, 2020Guru - Experienced User
Let us know how it goes for you.
- IcedCornApr 22, 2020Tutor
I have installed the 4200. I saw the price and then with the 10% netgear discount I would give it a shot. Basically it's $200 less (although I didn't realize until after the fact it was 6 antennas vs 8 antennas.
Speeds - both wired and wireless are working much better than with the old orbi. Before I had to go direct into the modem in order to max out, now I'm pretty close to max wired with the orbi connected as the router rather than an AP.
So far so good. It "feels" faster although I don't know if that's me justifying the purchase or it really is.. :)
