TheViking309
Dec 10, 2023Aspirant
AX4200 WiFi Mesh System (CBK752) Is it good to use?
I'm looking to replace my Spectrum modem and router. I'm wondering if it's a good idea to use the Orbi Tri-Band WiFi 6 Mesh System with Built-in Cable Modem, 4.2Gbps, Modem Router Combo + 1 Satellit...
TheViking309
They charge me five or tem a month for their equipment. I get new equipment every year, and I still have all the same issues with my internet. I have the EN2251 modem, and the SAX1V1S for the router. I've called numerous times for the speed and lag issues I have. When I'm hard wired in router and it takes several minutes to load Google, with 1gb speeds, and a gaming PC there's an issue. Even with getting new equipment it still happens. They say they will send a tech, but they won't find anything because I live in an apartment complex. I'd they fif find something it wouldn't be on my end, and they'd have to update their cables or something. The complex won't pay for that so I need to find a better solution.
Dec 10, 2023Guru - Experienced User
I believe Spectrum supports some model NG CM series modems. Check there supported modem list and see if any of the CM1000, 1100, 1200, 2000 are supported.
There also maybe ISP signal line issues up to there modem and they should be checking this as this is there side of the fence they have to maintain.
The following is what we post to users with problems with NG modems on ISP services and though may not apply to some, most cases some of this could be helpful:
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
Good Luck.
- TheViking309Dec 10, 2023Aspirant
All equipment used for my internet is provided by my ISP. I guess I'll just have to have them check the line. I don't have any splitters or anything, Just one cable going from the wall coax to the modem. I'll have to look into the LAN cable as again it is the one provided by the ISP. Thank you for all the help. I greatly appreciate it.
- FURRYe38Dec 11, 2023Guru - Experienced User
đ
- CrimpOnDec 11, 2023Guru - Experienced User
It is unusual for a residential dwelling to have zero splitters. Typically, cable lines run from the drop (mine is on a pole in the back yard) to the house, where a splitter is used to run cables to locations in the house where the customer wanted to locate television sets. There is often a separate coax cable to the location of the data modem.
I even have a splitter where the Tivo box requires a Tuning Adapter to manage switched digital video channels.
The phone issue remains. Ditch Spectrum phone, and you have more options (and more responsibility).
- TheViking309Dec 11, 2023Aspirant
I meant I don't have splitters from the wall to my modem. I don't know about anywhere else. I do plan on getting rid og the phone line. Just have to figure out the best solution for thr modem and router. I wish I could just ditch Spectrum completely, but they are the only ones to provide good internet speeds for what I need.
Let us know what you get.
