Chaaad614
Sep 12, 2020Star
AX4200 Wired Backhaul Peculiarities
My issue does not concern performance, but instead management/administration of the routers/satellites. Background: I have used the Orbi ac3000 system (1 RBR50 + 1 RBS50) in a wired backhaul arrangeme...
- Sep 12, 2020
Yes it's one of Orbi's "peculiarities" that I've learned to deal with and seems to be how NG has designed them.
The illustrations for the link is correct for connecting the RBS to the back of the RBR. The Internet port on the RBR is only used for it's main connection to the main host router in AP mode or an ISP modem when in router mode.
Sep 12, 2020Guru - Experienced User
Are the RBS directly wired to the back of the RBR or connected thru a LAN switch? If so, What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
NG is recommending currently to use CTS 64 on the Orbi AX system.
Chaaad614
Sep 12, 2020Star
Also, I can connect directly to the satellite via a browser and its Internet Address. When I do that, I see a reliable list (I think) of all its attached devices.
