Kyle6279
Mar 29, 2021Aspirant
AX6000 - Single iPhone won't save network password each time I return home
I installed the RBK853 (AX6000) and replaced my current router - used the exact same network name and password. All devices in my home connected seamlessly except for my iPhone 12 Pro which I used to...
Mar 29, 2021Guru - Experienced User
Not ever with any NG router or my Orbi AX system with a iphone 12 max I have. iOS 14.4.1. WPA2 and AES only.
Are you using any special characters in the SSID name or password on the RBR?
Forget the SSID name profile on the iphone then reconnect.
I would refer to Apple support for additional help and information regarding there product. Sounds like a iphone problem if this is the only device having this problem.
