tgorelick
May 07, 2020Tutor
AX6000 / RBK853 with Sonicwall TZ4000
When I configure my Orbi RBR850 router in AP mode, set the IP address to be obtained from my Sonicwall router, and connect the orbi to a Sonicwall LAN port, I cannot connect to the orbi's admin inter...
May 08, 2020Guru - Experienced User
Set a static IP address on the RBR. That was you always know where the IP address is and can always access the RBR. I use 192.168.0.85 for my system.
tgorelick wrote:When I configure my Orbi RBR850 router in AP mode, set the IP address to be obtained from my Sonicwall router, and connect the orbi to a Sonicwall LAN port, I cannot connect to the orbi's admin interface (using the Sonicwall assigned IP or orbilogin.com), cannot ping the orbi from any network device other than the Sonicwall's diagnostic page, and cannot access the internet from the orbi WiFi network. Netgear support advised me to leave the orbi in router mode but in its own subnet. (My Sonicwall is on 192.168.2.x.) I'd prefer to turn off the routing on the orbi, so everything in the same subnet. Suggestions?
tgorelick
May 09, 2020Tutor
Setting a static IP does not solve the problem.
