dstrausser83
Jan 10, 2020Guide
AX6000 + RBS50 Satellite's?
I'm seeing mixed messages here. Netgear tell me they won't work but I swear I've seen some posts that say they do work.... and the Orbi page says the routers are backwards compatible.... I basica...
ekhalil
Jan 11, 2020Master
Currently you can connect the RBS50 satellites wired (wired backhaul) to Orbi AX. Wireless backhaul support will come later.
- Chuck_MJan 12, 2020Mentor
The proof is in the pudding... look at this screen capture attached.
Notice the RBS850 is RF backhauled and the RBS50s (two of them) are hard wired. Works great.
- dstrausser83Jan 12, 2020Guide
Dang, I just sold them on Ebay but perhaps I can cancel it... my issue is I wasn't able to get it to pair while wired also it seems... Does it do it automatically or do I have to still pair them? Just connect the Ethernet and it is connected? When I did that the light was blue but I didn't check the app to see if it was recognized.... Interesting, perhaps I will keep it then if that's the case.
They pair automatically when wired. You dont have to do anything other than plug in.
