dstrausser83
Jan 10, 2020Guide
AX6000 + RBS50 Satellite's?
I'm seeing mixed messages here. Netgear tell me they won't work but I swear I've seen some posts that say they do work.... and the Orbi page says the routers are backwards compatible.... I basica...
ekhalil
Jan 11, 2020Master
Currently you can connect the RBS50 satellites wired (wired backhaul) to Orbi AX. Wireless backhaul support will come later.
Chuck_M
Jan 12, 2020Mentor
The proof is in the pudding... look at this screen capture attached.
Notice the RBS850 is RF backhauled and the RBS50s (two of them) are hard wired. Works great.
