dstrausser83
Jan 10, 2020Guide
AX6000 + RBS50 Satellite's?
I'm seeing mixed messages here. Netgear tell me they won't work but I swear I've seen some posts that say they do work.... and the Orbi page says the routers are backwards compatible.... I basica...
Sevo123
Jan 25, 2020Apprentice
Ok so I have a Rbk853 ( 1rbr 2 rbs ) hardwired backhaul I also have 1 rbs50 which is hooked up hardwired backhaul. The problem is I'm right next to the rbs50 but everything will connect to the rbs850 even in far location it will use 2.4 and avoid the rbs50 2 feet away. This happens with all devices even ones with without wifi 6 support??? What is going on? Maybe Netgear was right they don’t work or work well together? Cant wait to purchase the rbs850 and switch this out
Chuck_M
Jan 25, 2020Mentor
Have you ever had anyone talk too loud to you when they are too close? You cant understand what they are trying to say.
That may be what is going on in your case. You can try and go into advanced and wireless settings and turn down the power output to see if that will allow the close device to connect.
