dstrausser83
Jan 10, 2020Guide
AX6000 + RBS50 Satellite's?
I'm seeing mixed messages here. Netgear tell me they won't work but I swear I've seen some posts that say they do work.... and the Orbi page says the routers are backwards compatible.... I basica...
Chuck_M
Jan 25, 2020Mentor
Have you ever had anyone talk too loud to you when they are too close? You cant understand what they are trying to say.
That may be what is going on in your case. You can try and go into advanced and wireless settings and turn down the power output to see if that will allow the close device to connect.
Sevo123
Jan 25, 2020Apprentice
1) everything used to connect to the old rbs 50 when my rbk53 was installed.
2) I have devices that are further out about 10ft and 20ft and more from this rbs50 with no other satellites near by.
3) I checked everywhere with Netgear support they are saying the rbs 50 will not work with the rbk853 unit... ( but Idno if I believe them)
4) I lowered down the power level as you stated and nothing changed.
- FURRYe38Jan 25, 2020Guru - Experienced User
NG has NOT officially made RBS50s FULLY COMPATIBLE with Orbi AX. RBS50s will not sync to the Orbi AX system! Though wired RBS50s should work ok, some have been tracking a problem in recent FW versions of the RBS50 seeing a "disconnect" message in the RBR850's connected clients page.
If you have the RBK853 system, I would ditch the RBS50 until NG makes them fully compatible. So far there is no timeframe when this might happen.
- Chuck_MJan 26, 2020Mentor
What firmware is in the RBS50? I have two hard wired to my RBR850 and it works well.
