Halewafa
Jul 21, 2020Guide
AX6000 and MetroNet Connection Issues
Hi all, Here’s the story: I had the RBR50 system for two years and it worked flawlessly. A few days ago we had a power outage and it just stopped working. I did a factory reset and fresh setup, i...
- Jul 24, 2020
Thanks Fury,
So I finally got it working,... just praying it stays working and I don't have another power outage.
I tried resetting the ONT and doing a factory reset on the Orbi, didn't fix it, still couldn't get internet during setup. I then tried something else mentioned in another forum. Plugged a laptop directly into the ONT and did a ipconfig/release and then ipconfig/renew. Then plugged the ONT into the Orbi (which was reset again) and did the setup via a laptop plugged directly into the Orbi. During the setup it failed again, still couldn't get internet. Tried the setup via the Orbi app wirelessly and what do you know... it worked. I have no clue what happened, but everything is up and running beautifully. getting 950/950 up/down on my gaming computer connected directly to the satellite (which is hardwired to the main router).
Thanks for all your help, have a great weekend!
