TimNielsen
May 29, 2020Aspirant
AX6000 Download consistently slower than upload across backhaul...
So I have gigabit internet on fiber. With a wired connection to the net, I get consistently 900 up and down. I'm trying both an Orbi AC3000 setup, and an AX6000 that I just got today. I have my M...
May 29, 2020Guru - Experienced User
What fibre ont/gateway are you connected to?
- TimNielsenMay 29, 2020Aspirant
Looks to be custom branded by my internet provider, Sonic, here in CA. I only have a P/N which I assume is part number128778F1N
- plemansMay 29, 2020Guru - Experienced User
I couldn't find anything for that #. Any other model numbers on it?
Nope, sadly no... Again it's not the modem. If I directly wire ethernet to from the computer to the Orbi base station, I get 900+ up and down. So it doesn't have anything to do with the modem. It's purely somethiung related to the backhaul connection between the base and satelite, either something interfering on the frequency, but dout that... or some setting...
