Captainmichael7
Nov 20, 2021Aspirant
Ax6000 download speeds max at 94 mbps via ethernet and wifi
I am only receiving 94 mbps via wifi and ethernet on all devices.. new orbi rbk 853 setup.. I have changed multiple settings and I have now downgraded firmware.. I am stuck at 90 mbps... If I connect ...
- Nov 20, 2021Yes, that is correct.. still only shows 100 mbps
Captainmichael7
Captainmichael7
Ughhh my son just clicked that as a solution.... this has obviously not been resolved..
So it appears that the hardware is defective.. Am I correct?? but how do I convince them to RMA?? They just keep coming up with different excusues...
- FURRYe38Nov 20, 2021Guru - Experienced User
Ya, something is happening on the RBR that when connecting to two different 1000Mpbs connections is NOT getting that link rate on the RBR. If resets and power cycles are not helping, then the HW needs to be replaced.
You can show them this thread.
You can also reach out to a forum moderator and have them review this as well and have them direct you.
