Tangmu
Dec 29, 2019Star
AX6000 Issues
I replaced an Orbi Pro system with the AX6000 today. I set it up with the same SSID and password. Most devices are working fine on it with a few exceptions: Amazon Firestick freezes every few min...
- Dec 31, 2019
Updating the WiFi drivers on the one Lenovo (Thinkpad) got it going.
The weather station's web site shows it has an issue with web networks in general, although mine was working on the Orbi Pro. Their solution is disconnect the satellite, reboot the base, and then look for the SSID. After that you can reconnect the satellite.
For the Firestick, a couple of power cycles got it working with no issues. I have a 2nd Firestick and it worked without any extra effort.
Tangmu
Dec 31, 2019Star
Dec 31, 2019Guru - Experienced User
Good to hear. Glad you got it working. Please mark your thread as solved so others will know.
Enjoy.
