calligulla87
Mar 14, 2023Aspirant
AX6000 Mesh system (RBR850+1xRBS850)-very slow Wi-Fi or even disconnect
Hi, Issue description: about 3 months after I bought and installed my Orbi RBR850 with one satellite RBS850 Wi-Fi system, I started experiencing very slow bandwidth on both, laptops and iOS devi...
- Mar 18, 2023Mystery resolved. I had a T-Mobile LTE extender box installed in my office about 7 years ago. As soon as I unplugged it, the WiFi started working flawlessly. Why that wasn’t a problem last year, I don’t know. But the radio signals between the receiver in my office and the sender on the 1st floor must have interfered with the Orbi WiFi.
Crazy!
CrimpOn
Mar 14, 2023Guru - Experienced User
Is there a difference in the ICMP (ping) results between computers connected with Ethernet and computers connected with WiFi?
It might be useful to open two command windows and simultaneously ping:
- an internet resource, such as google.com, and
- a local device that responds to ICMP. (Windows requires a firewall change to respond to ICMP.) The Orbi router responds to ICMP on the LAN side.
- calligulla87Mar 14, 2023Aspirant
Both pings are very similar. The issue is that on the 2nd floor I only get about 10 MBit/s bandwitdh on my computers and 1 MBit/s on iOS devices or even dropped connections. It's terrible.
