SS_Italy
Mar 29, 2022Aspirant
AX6000 Orbi RBK853 unstable quality and not good performance
hi guys, i have a RBK853 — Orbi WiFi 6 System AX6000 system on my home.. a RBR + 2 Satellite. The configuration is pretty easy, RBR is configured as WIFI Mode, it is connected via Gigabit LAN t...
Mar 29, 2022Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
What CAT# cable are you using thru out the home? CAT6 is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Set CTS to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Be sure any wifi adapter drivers are up to date.
Windows 10 or 11 on this pc?
SS_Italy
Italian provider EOLO, WIFI connection
I use Mikrotik Routerboard 2011UiAS
All internal cabling are 5E.. Ethernet connection is stable and no packet drops.
300 mq on 3 differents levels
Router is on the top, on my office.
First satellite is on level 0 .. it is about 20 mt.. and the second satellite is on basement other 20 metres or something more.
6 for 2,4 and 48 for 5Gg
I'm alonme in the dark.. just another dedicated wifi for s Nintendo Switch of my daughter.
ok
Ubunto Linux.. driver are up to date.
