SS_Italy
Mar 29, 2022Aspirant
AX6000 Orbi RBK853 unstable quality and not good performance
hi guys, i have a RBK853 — Orbi WiFi 6 System AX6000 system on my home.. a RBR + 2 Satellite. The configuration is pretty easy, RBR is configured as WIFI Mode, it is connected via Gigabit LAN t...
SS_Italy
Italian provider EOLO, WIFI connection
What is the Mfr and model# of the ethernet switch in the configuration?
I use Mikrotik Routerboard 2011UiAS
What CAT# cable are you using thru out the home? CAT6 is recommended.
All internal cabling are 5E.. Ethernet connection is stable and no packet drops.
300 mq on 3 differents levels
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Router is on the top, on my office.
First satellite is on level 0 .. it is about 20 mt.. and the second satellite is on basement other 20 metres or something more.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
6 for 2,4 and 48 for 5Gg
I'm alonme in the dark.. just another dedicated wifi for s Nintendo Switch of my daughter.
Set CTS to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
ok
Be sure any wifi adapter drivers are up to date.
Windows 10 or 11 on this pc?
Ubunto Linux.. driver are up to date.
Mar 29, 2022Guru - Experienced User
Might try channel 1 and 40 as well.
Can you compare ping results with a different PC or laptop to compare results?
I would also turn OFF the RBS's and then run a PING test with the PC around 2-3 meters away from the RBR.
I would also bring the distances between the RBR and RBSs to say 10-15meters. 20meters maybe a bit too far.
