J-dawg83
Mar 20, 2022Guide
AX6000 Orbi RBK853 wifi disconnects
Hi there 🙂 I'm at the point where im almost pulling out my hair haha My setup is as follows: Network Terminating Unit - supplied by ISP (CABLE) My personal router - D-link DSR 1000AC Orbi...
- Mar 28, 2022
Thanks everyone for trying to help.
I have tried a lot of things now, none seemed to have work... after 4 solid days of trying to work this out, I have given up and requested refund. I have now switched to Unifi routers which work a dream around my property. I'm not sure why Orbi was so difficult, would have thought an off the shelf product would be more plug and play given the price tag. Software was also rather average, disappointing 😞
J-dawg83
Mar 20, 2022Guide
One thing i did forget to mention, I am running ethernet backhawl
Oh and its a RBR850 not RBR853
- plemansMar 20, 2022Guru - Experienced User
What firmware is on the router and on the satellites?
- J-dawg83Mar 20, 2022Guide
Hey mate 🙂
All 3 including router are sitting on V4.6.3.16
You might try the newer version of firmware. Supposedly there was fixes for backhaul issues.
https://www.netgear.com/support/product/rbk852.aspx#download
I'd recommend updating the satellites first and then the router.
Sometimes a factory reset after the update can help as well.
