rsghowellnj1
Feb 22, 2021Aspirant
AX6000 Outdoor Satellite Support
I'm interested in upgrading to the ORBI AX6000 but wanted to know if you offer an outdoor satellite that is compatible with this system.
olias33
Apr 29, 2021Aspirant
You are accurate that an indoor Orbi satellite tv for pc located without delay next to the outdoors wall will broadcast pretty a bit to the outdoor. It will even value a lot much less than the RBS50Y as you canread. Even better, set it up in a windows (non-steel glass, of path).
