jim_dandy_100
Mar 02, 2021Aspirant
AX6000 (RBK852 or RBR850) Zoom Drops w/WiFI
Wife's HP Notebook 15t-da000CTO work great with Zoom when using ethernet but drops out a lot when using wifi. Wifi card in HP is a realtek RTL8822BE PCIe adapter. Computer was bought in December 2...
Axolotl_
Apr 23, 2021Aspirant
Did you manage to resolve the issue? Im experiencing the same issue with zoom on a HP chromebook.
I have the RBR850 in AP mode and using the BT homehub. The internet connection is 900MB and i consistently get 200Mbps around the house. I don't experience any issues when on ethernet, so i'm guessing its something to do with the WIFI.
Apr 23, 2021Guru - Experienced User
Try setting CTS value to 2347 on the RBR. Under Advanced Tab/Advanced Settings/Wireless Settings
Axolotl_ wrote:Did you manage to resolve the issue? Im experiencing the same issue with zoom on a HP chromebook.
