_r_y_a_n
Sep 06, 2023Aspirant
AX6000 (RBK852) WiFi in AP Mode seems slow (not double NAT)
Hi All, I have a RBK852 system (RBR850 + RBS850) setup in AP mode. (Firmware Version V4.6.14.3_2.3.12) When I speed test from http://routerlogin.com it consistently gives more than 900Mbps. (Most r...
_r_y_a_n
Yes,
The iPad is the iPad Pro M1 with the following WiFi specs:
802.11ax Wi-Fi 6
The laptop is a MacBook Pro with the following WiFi:
802.11ac Wi-Fi wireless networking; IEEE 802.11a/b/g/n compatible
Sep 06, 2023Guru - Experienced User
What are the MIMO specs of the apple devices? 2x2 ? Higher?
Most 2x2 MIMO devices top our at around 300-600Mpbs depending on design and support and distances from closest source signal.
Most I have see on my 2018 MBP is around 700Mbps when close to a signal source. On average, it's around 500-600 depending on where I'm at in the home.
What are ethernet connected speeds using Ooklas installable speed test app and the PC connected at the RBR?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
