Nsiddons
Oct 25, 2019Apprentice
AX6000, RBR852, or RBR850 isn't compatible with RBS50Y
So I ran to Best Buy to get the new RBR852 AX6000 Orbi. Hardware installation was easy and quick. I ran into my first issue when I tried to load my backup from my RBR50 but it wasn't compatible ok no...
CrimpOn
Oct 25, 2019Guru - Experienced User
This is a question people have been asking for several months. "Will existing satellites function with the new "AX" Orbi product?"
If the RBS50Y was previously connected to a different Orbi router, you may need to do a "factory reset" on the RBS50Y before attempting to connect it to the new AX router.
skyward1
Jan 08, 2020Apprentice
According to Netgear Tech Support, the RBS50Y outdoor satellite and the new RBR850 router, are not compatible.
There is supposed to be a FW update in the "first week of January" (we're there now) that will fix this issue.
The current firmware version is V3.2.8.5_1.2.3
Let's see what happens...
- skyward1Jan 18, 2020Apprentice
Here's an update...
Netgear pushed firmware V3.2.9.2_1.2.4 to the RBR850 router and RBS850 satellite, just over a week ago. The issue remains unchanged; the RBS50Y outdoor satellite will not link with the new RBR850 router. Netgear support has not responded to my ticket so, I'm sending my RBS50Y back to Amazon, before the return window closes. It's strange how they remain so quiet.
- FURRYe38Jan 18, 2020Guru - Experienced User
Thanks for letting us know.
- Hitchcock3May 27, 2020Tutor
Updated to V3.2.15.25_1.3.15. No change. Still can't add the RBS50Y to the RBR850.
Shipping the RBS50Y back to BestBuy tomorrow.
