Nsiddons
Oct 25, 2019Apprentice
AX6000, RBR852, or RBR850 isn't compatible with RBS50Y
So I ran to Best Buy to get the new RBR852 AX6000 Orbi. Hardware installation was easy and quick. I ran into my first issue when I tried to load my backup from my RBR50 but it wasn't compatible ok no...
Jan 18, 2020Guru - Experienced User
Thanks for letting us know.
Hitchcock3
May 27, 2020Tutor
Updated to V3.2.15.25_1.3.15. No change. Still can't add the RBS50Y to the RBR850.
Shipping the RBS50Y back to BestBuy tomorrow.
- FURRYe38May 27, 2020Guru - Experienced User
I presume FW will have to be updated on the RBSY as well. Thanks for letting us know.
Be sure to post about any Orbi AX questions or problems over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Have a good day.
Hitchcock3 wrote:Updated to V3.2.15.25_1.3.15. No change. Still can't add the RBS50Y to the RBR850.
Shipping the RBS50Y back to BestBuy tomorrow. - skyward1May 27, 2020Apprentice
Hitchcock,
I just read on the Netgear products page that the AC3000 outdoor satellite will work in the extender mode with AX6000. Due to the difference in technology between the AC and AX, it will not work in Orbi mode. It looks like it could be a while before it can join a WiFi 6 mesh, if it ever can. https://www.netgear.com/orbi/rbs50y.aspx?_ga=2.215678231.1011596647.1590616610-771620495.1577827822
-sky
- Hitchcock3Jun 03, 2020Tutor
So after wrestling with this thing quite a bit, I think I got it to work. First I had to set it up in extender mode to connect it to the internet and upgrade the firmware.
I was unable to add the RBS50Y via the admin interface. But hitting the sync buttons on the two devices they did appear to negotiate a connection. After a while I got a solid blue light on the RBS50Y and it went dark a few minutes later, which is supposed to indicate a good connection. Using a wifi analisys tool I saw two new networks (2.4 & 5). using the utility I was able to walk around my back yard and maintain a connection to the new networks and to the internet. So I think I have it working.
The RBS50Y still does not show up in the admin interface or on either Android or iOS App.
- FURRYe38Jun 03, 2020Guru - Experienced User
So extender mode on the RBSY workes. Kewl. Ya, I presume Orbi App and the RBRs web page will still not be compatible until NG gets them to work fully.
