Nsiddons
Oct 25, 2019Apprentice
AX6000, RBR852, or RBR850 isn't compatible with RBS50Y
So I ran to Best Buy to get the new RBR852 AX6000 Orbi. Hardware installation was easy and quick. I ran into my first issue when I tried to load my backup from my RBR50 but it wasn't compatible ok no...
Hitchcock3
Jun 03, 2020Tutor
I'm really not sure what mode it is in. I followed the process for adding a Satellite. But I did it without using the admin web page or app. I just hit the sync buttons on both devices.
I double checked and contrary to what I said previously, the device does appear in the Admin tools, but it is showing up as a device, not as a satellite. It actually shows up twice. If I hit one of the IPs in the browser it says it can't be reached. If I hit the other IP, it is the extender setup page. I'm not going to go through the extender setup process becasue, as I said, before, it is actually working, so I'm not going to mess with it.
It seems possible that it is in extender mode. If Netgear says it isn't going to work as a satellite I'm inclined to believe them. However from a connecting device perspective there is only one SSID. Using the Wifi analizer (I'm using NetSpot) I see 6 networks with 6 separate MAC addresses for the AP. (Router, Indoor Satelite, Outdoor Satelite, each with a 2.4 and 5Ghz network) I can wonder around the house and yards and I can see the device flipping between the different networks depending on signal strangth.
Jun 04, 2020Guru - Experienced User
So did you load the Extender mode FW on the RBSY? IF you did then the RBSY is using extender or repeater mode. There would be no backhaul support like the RBS850 will have which would be the difference.
Untill NG makes the RBS50 series compatible, they won't appear in the satelllite connected section.
Hitchcock3 wrote:I'm really not sure what mode it is in. I followed the process for adding a Satellite. But I did it without using the admin web page or app. I just hit the sync buttons on both devices.
- edellefemineJul 17, 2020Aspirant
Circling back on this - so are the AX Wifi 6 products and RBS50Y outdoor extender still not compatible?
- CrimpOnJul 17, 2020Guru - Experienced UserThe RBS50Y will not integrate as a "satellite" with anything but the original WiFi5 Orbi. So. In that sense, "no". If the "extender" firmware is loaded, it is supposed to act as an ordinary WiFi extender with any WiFi router.
