grady7
Oct 26, 2020Aspirant
AX6000 reboot / reconnect slow
Hi, I've been using my orbi ax6000 for a few months, and mostly love it. My one issue is that I regularly have to reboot my xfinity router due to local slowdowns. Whenever I reboot the route...
- Nov 07, 2020
I'd make contact with NG support. Ask about an RMA.
Oct 26, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Build in router here by chance? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
grady7
Thanks for your help! Answers below.
- v3.2.16.6
- Arris Model TG1682G
Couple of options,
- I will read through these, and see if I need to reach out to the ISP. I should be able to figure out how to disable the wifi radios.
