sureshsumithra
Aug 17, 2020Aspirant
AX6000 WiFi can be connected with Huwai CPE pro Wifi 6 Router
Orbi AX6000 WiFi can be connected with Huwai CPE pro Wifi 6 Router
Aug 17, 2020Guru - Experienced User
Are you asking if it can?
If so, yes you can. It can cause a double nat with 2 routers running in router mode. But there's ways around that.
