sureshsumithra
Aug 17, 2020Aspirant
AX6000 WiFi can be connected with Huwai CPE pro Wifi 6 Router
Orbi AX6000 WiFi can be connected with Huwai CPE pro Wifi 6 Router
Aug 17, 2020Guru - Experienced User
Yes but not generally recommended. You can do double NAT if you use the host routers DMZ.
Or configure the Orbi base router for AP mode, leaving the host router has your main router and disable the main routers wifi radios.
sureshsumithra wrote:Orbi AX6000 WiFi can be connected with Huwai CPE pro Wifi 6 Router
- sureshsumithraAug 17, 2020AspirantHuawei CPE ROUTER COMES WITH SIM card slot.
IF I CONNECT THE LAN connection of HUWAI CPE to LAN connection of AX6000wifi router.
It will work in this way?- FURRYe38Aug 17, 2020Guru - Experienced User
Yes.
So the Huwei is a LTE cell phone wifi router?
If this router has a DMZ, please use this feature if you use the RBR in router mode. If not, then you'll need to configure the RBR for AP mode.
- sureshsumithraAug 17, 2020AspirantYes HUWAEI is a LTE cell phone wifi router.
This router is having DMZ.
If I enable that . Then I can normally connect the huwai router and AX 6000 WiFi router through LAN
Please find the back side of the router ( photo attached).
Please guide . If it is compatible , I will buy.
