sureshsumithra
Aug 17, 2020Aspirant
AX6000 WiFi can be connected with Huwai CPE pro Wifi 6 Router
Orbi AX6000 WiFi can be connected with Huwai CPE pro Wifi 6 Router
sureshsumithra
Huawei CPE ROUTER COMES WITH SIM card slot.
IF I CONNECT THE LAN connection of HUWAI CPE to LAN connection of AX6000wifi router.
It will work in this way?
Aug 17, 2020Guru - Experienced User
Yes.
So the Huwei is a LTE cell phone wifi router?
If this router has a DMZ, please use this feature if you use the RBR in router mode. If not, then you'll need to configure the RBR for AP mode.
- sureshsumithraAug 17, 2020AspirantYes HUWAEI is a LTE cell phone wifi router.
This router is having DMZ.
If I enable that . Then I can normally connect the huwai router and AX 6000 WiFi router through LAN
Please find the back side of the router ( photo attached).
Please guide . If it is compatible , I will buy.- sureshsumithraAug 17, 2020Aspirant
Further to my below reply, please correct me if am wrong
- Connecting the Ethernet Cable to AX6000 Wifi router and Huwaei CPE Cellphone wifi router.
- Then configure the AX6000 Wifi router to act as an access point.
- Then i can add all the satellites to the access point.
This is the way i have to go.
- FURRYe38Aug 17, 2020Guru - Experienced User
Yes use the DMZ on the cell phone router for the RBR then you can use the RBR in router mode.
- sureshsumithraAug 17, 2020AspirantThanks for your reply.
Once ports are forwarded after enabling DMZ in cell phone router . Then Ax6000wifi will be in router mode.
After that one router only active that is AX6000 WiFi
My cellphone router will be forwarding the ports to AX6000wifi.
Please correct me I f iam wrong
