sureshsumithra
Aug 17, 2020Aspirant
AX6000 WiFi can be connected with Huwai CPE pro Wifi 6 Router
Orbi AX6000 WiFi can be connected with Huwai CPE pro Wifi 6 Router
sureshsumithra
Yes HUWAEI is a LTE cell phone wifi router.
This router is having DMZ.
If I enable that . Then I can normally connect the huwai router and AX 6000 WiFi router through LAN
Please find the back side of the router ( photo attached).
Please guide . If it is compatible , I will buy.
sureshsumithra
Further to my below reply, please correct me if am wrong
- Connecting the Ethernet Cable to AX6000 Wifi router and Huwaei CPE Cellphone wifi router.
- Then configure the AX6000 Wifi router to act as an access point.
- Then i can add all the satellites to the access point.
This is the way i have to go.
