sureshsumithra
Aug 17, 2020Aspirant
AX6000 WiFi can be connected with Huwai CPE pro Wifi 6 Router
Orbi AX6000 WiFi can be connected with Huwai CPE pro Wifi 6 Router
Aug 17, 2020Guru - Experienced User
Yes use the DMZ on the cell phone router for the RBR then you can use the RBR in router mode.
sureshsumithra
Thanks for your reply.
Once ports are forwarded after enabling DMZ in cell phone router . Then Ax6000wifi will be in router mode.
After that one router only active that is AX6000 WiFi
My cellphone router will be forwarding the ports to AX6000wifi.
Please correct me I f iam wrong
- FURRYe38Aug 18, 2020Guru - Experienced User
No port forwarding should be needed if you use the DMZ on the ISP modem for the Orbi RBR. However onces the DMZ is configured for the RBR, it your phone should connect well and get internet services thru the RBR and out thru the ISP modem.
