DudeDah
Mar 09, 2023Aspirant
AX6000 Wired backhaul question...NEWB
So I am going to use a wired backhaul configuration for my RBS, is it "better" or does it matter whether I use the "Link aggregation" port on the back of the RBR vs. one of the other three?
- Mar 09, 2023
How Ethernet port 1 behaves is determined by a setting on the Advanced Tab, Setup Meu, Internet Setup.
- Enabling Link Aggregation means port 1 is connected to the modem.
- Not enabling Link Aggregation means port 1 is just like ports 2-4 (connected to devices on the LAN).
See the user manual for the specific model of Orbi router (found on the product label on the bottom of the router).
Mar 09, 2023Guru - Experienced User
LAG is the for WAN side.
WIred will always be better than wireless.
- DudeDahMar 09, 2023Aspirant
So then the Ethernet cable running to/from the Satellite should connect into one of the ports 2-4 and NOT the LAG port on the RBR?
- FURRYe38Mar 09, 2023Guru - Experienced User
U can connect to the port 1 (LAG port) if you don't have LAG enabled on the RBR. IF you do then yes, ports 2-4.
- CrimpOnMar 09, 2023Guru - Experienced User
