kleek1975
Aug 25, 2020Guide
AX6000 Wired Ethernet Backhaul issues
My setup: AT&T LIGHTSPEED (950 Mbps up/ 930 down) to Arris BGW210 Router (serves as Gateway and DNS Server) to Netgear Insight GC728XP 28 port managed switch to 1) RBR850 Orbi Router in Access Point...
kleek1975
Aug 25, 2020Guide
Thanks FURRYe38. Went ahead and disabled the IGMP Snooping protocols on the switches and rebooted the Orbi router and satellites. Still no ethernet backhaul. Any other suggestions?
Aug 25, 2020Guru - Experienced User
Lets make sure the RBS are working with ethernet, can you directly connect the RBS to the back of the RBR with out a switch in the middle?
- kleek1975Aug 25, 2020Guide
That's affirmative. Wired ethernet backhaul works just fine when I plug the satellite orbi directly into the router orbi without switches.
- FURRYe38Aug 25, 2020Guru - Experienced User
Something else on these switches is not working right or preventing RBS data from flowing correctly between the RBR and RBS, thus causing the RBB to wireless connect for backhaul instead of wired. I recommend you try a non managed non green ethernet switch and see if this changes the behavior. I presume it will.
