rdasketes
Oct 31, 2020Aspirant
AX6000/RBK852 - does Netgear even use these in real life before releasing them?
I love spending $1000 on a system that is so limiting (alledgedly to be easy) and yet more than half of the "smart" devices in the real world cannot leverage 5ghz networks to be connected. The O...
rdasketes
Nov 01, 2020Aspirant
I appreciate the thoughtful response. I've already changed them down to 25% in the attempt to try and get the 2G network. No dice.:/
Nov 01, 2020Guru - Experienced User
Disabling of AX mode on 2.4Ghz?
- rdasketesNov 01, 2020AspirantI didn't think of that one. I'll try it when I get home and report back in. Thanks!
- FURRYe38Nov 01, 2020Guru - Experienced User
:smileywink:
- rdasketesNov 02, 2020Aspirant
Okay, so I had my phone "forget my wifi", turned off my phone, then disabled all AX components, moved 5Ghz down to 25% power for swapping, unplugged my two satellites, rebooted the AX6000 router, turned my phone on, then freshly connected to the wifi and am still on the 5GHZ network. :smileymad:
