Mahesh-GGN
Jul 03, 2021Follower
AX6000/RBK852 - Guest Network - No internet when connected through the satellite
Orbi Netgear RBR-850 and RBS-850 both runing with latest Firmware V3.2.18.1 and facing "No internet on Guest SSID"
After making any/simple modification (Wireless Setup ---> Enable AX ---> "Enable 2.4G" tried to disable once and reverted back) in configuration and after it "No internet" on the "Guest SSID / Network" although wireless devices properly gets connected to Guest SSID. Even after reverting back to orginaly/previous setting issue persist i.e no internet on the guest SSID network anymore.
1 Reply
Wireless Setup ---> Enable AX ---> "Enable 2.4G" Does nothing to effect Guest Network services. Just enables or disable the AX mode across the system.
Be sure that "Enable SSID Broadcast: is enabled under Basic tab/Guest Network.
Be sure RBS is synced fully with the RBR.
Ensure that FW loaded on the RBS is the same as the RBR.
Is Armor enabled on the RBR? Disable it as a test.
Try a factory reset on the RBR and RBS and setup from scratch
