philoouu
Aug 20, 2020Luminary
AX6000/RBK852 Missing Telnet access
Dear all, I just bought a AX6000/RBK852 (RBK850/RBS850) with the lattest firwmare V3.2.16.6 and I need to have telnet access to be able to change Guest Network IP Range. In the http://orbilogin.com...
Retired_Member
Aug 20, 2020philoouu
Aug 21, 2020Luminary
Thanks for coming back to me.
This is pretty heavy compared to just enabling telnet on the GUI.
Do you know if there is anything available on Mac ?
Thanks
- Retired_MemberAug 21, 2020
Not aware of any other way to enable telnet on the new units.
Virtual machine with windows or linux will do it for you :)
- philoouuAug 21, 2020Luminary
Understood. I wish the GUI would have much more options available.
I just realized the gest network was not even working through the satellite with a wired backhaul... No need to change the IP range in that case for the moment !
Hard to believe that there is bug like that for such an expensive device !
Anyway thanks a lot for your help.
Regards
- FURRYe38Aug 21, 2020Guru - Experienced User
Telnet was removed a while back. No sure if it's coming back to Orbi AX.
