philoouu
Aug 21, 2020Luminary
AX6000/RBK852 Wired Backhaul mode - Guest Network - No internet when connected through the satellite
I just bought a AX6000/RBK852 (RBK850/RBS850) with the lattest firwmare V3.2.16.6. I have a lan cable connected between my main and the satellite (wired backhaul mode). I have a guest network too. W...
- Feb 03, 2021
I finally updated to v3.2.17.12.
After a reboot (exactly 2 reboot of the RBR as for some reason there was no internet connection during the first reboot and one reboot of the RBS), guest network is working correctly with the satellite in Wired Backhaul mode.
I did not need to do factory reset / reload my configuration.
Finally Netgear was able after 6 months to fix this basic function.
I wrote to the support desk to tell them the issue was solved.
FURRYe38 thanks for your help during these 6 months...
aedris
Aug 21, 2020Aspirant
I have the exact same setup and problem as OP philouu. Latest firmware on router and satellites, wired Backhaul, router mode. I don’t think anyone has answered OP question.
Aug 22, 2020Guru - Experienced User
Guest network is working for me and one other using v6 FW. RBS are wired, mine is using switches in between the RBR and RBS.
Is your RBS directly wired to the RBR or are there switche(s)in between? If so, what is the mfr and model# of these switch(s)?
Remove the switch(s) and directly connect the RBS to the RBR and test GN again.
