philoouu
Aug 21, 2020Luminary
AX6000/RBK852 Wired Backhaul mode - Guest Network - No internet when connected through the satellite
I just bought a AX6000/RBK852 (RBK850/RBS850) with the lattest firwmare V3.2.16.6. I have a lan cable connected between my main and the satellite (wired backhaul mode). I have a guest network too. W...
- Feb 03, 2021
I finally updated to v3.2.17.12.
After a reboot (exactly 2 reboot of the RBR as for some reason there was no internet connection during the first reboot and one reboot of the RBS), guest network is working correctly with the satellite in Wired Backhaul mode.
I did not need to do factory reset / reload my configuration.
Finally Netgear was able after 6 months to fix this basic function.
I wrote to the support desk to tell them the issue was solved.
FURRYe38 thanks for your help during these 6 months...
Jan 21, 2021Guru - Experienced User
Have you tried this yet?
Mywayout wrote:Tagging this as I have the same issue. Thanks for all the work on chasing it down
Mywayout
Jan 21, 2021Tutor
Sorry - it took me a few minutes until my wife let me take the internet down :) That worked!! Anyone else on the thread - this firmware version wasn't available on the auto-update but the firmware in the link provided fixed it - I had checked prior to posting in the thread.
- FURRYe38Jan 21, 2021Guru - Experienced User
Good to hear. Thanks for letting us know.
Mywayout wrote:Sorry - it took me a few minutes until my wife let me take the internet down :) That worked!! Anyone else on the thread - this firmware version wasn't available on the auto-update but the firmware in the link provided fixed it - I had checked prior to posting in the thread.
