Dtm316
Dec 26, 2021Guide
axe11000 Device connection issues
hello all. First timer here. I have the orbi axe 11000 with the router and 2 satellites connected. I have a pc and a PlayStation that have connection issues. It seems to be switching between a further...
Dec 27, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Dtm316 wrote:
hello all. First timer here. I have the orbi axe 11000 with the router and 2 satellites connected. I have a pc and a PlayStation that have connection issues. It seems to be switching between a further away satellite and the router. The orbi app currently says it’s not connected but the settings on the ps4 say the signal is 100% and connected to the 5ghz network. The app also show no IP address I also have been having some smart home devices having difficulty. I’m an apple HomeKit user so everything has to be on the same network for it to work properly. I have noticed I have to turn off the 5ghz add the device then reconnect the 5ghz network. Firmware is 6.0.3.68.
- Dtm316Dec 27, 2021GuideModem is NETGEAR cm205v
Home is about 1400sqft
Satellite 1 is located on the same floor 30-40 feet away from the router.
Satellite 2 is on the second floor Also about 35 feet away from the router.
Home is Sheetrock and wood studs
Should I turn the power to 50% for the 2.4 or the 5ghz?- FURRYe38Dec 28, 2021Guru - Experienced User
Home is about 1400sqft <For this size of home, you may only need the RBR. The additional RBS maybe over saturating the are with too much wifi. I have a 5000sq ft home and I can get away with running the RBR and just 1 RBS.
What happens if you turn OFF 1 of the RBS? Try the one on the same floor as the RBR.
Should I turn the power to 50% for the 2.4 or the 5ghz? Both radios.- Dtm316Dec 28, 2021Guide
Thanks for the reply. I unplugged the RBS on the first floor and moved the one on the second floor to the furthest spot possible away from the RBR. I cut the power to 50% on both networks as well. Will monitor over the next few days and report back.
