Dtm316
Dec 26, 2021Guide
axe11000 Device connection issues
hello all. First timer here. I have the orbi axe 11000 with the router and 2 satellites connected. I have a pc and a PlayStation that have connection issues. It seems to be switching between a further...
Dtm316
Dec 27, 2021Guide
Modem is NETGEAR cm205v
Home is about 1400sqft
Satellite 1 is located on the same floor 30-40 feet away from the router.
Satellite 2 is on the second floor Also about 35 feet away from the router.
Home is Sheetrock and wood studs
Should I turn the power to 50% for the 2.4 or the 5ghz?
Dec 28, 2021Guru - Experienced User
Home is about 1400sqft <For this size of home, you may only need the RBR. The additional RBS maybe over saturating the are with too much wifi. I have a 5000sq ft home and I can get away with running the RBR and just 1 RBS.
What happens if you turn OFF 1 of the RBS? Try the one on the same floor as the RBR.
Should I turn the power to 50% for the 2.4 or the 5ghz? Both radios.
- Dtm316Dec 28, 2021Guide
Thanks for the reply. I unplugged the RBS on the first floor and moved the one on the second floor to the furthest spot possible away from the RBR. I cut the power to 50% on both networks as well. Will monitor over the next few days and report back.
- Dtm316Dec 28, 2021GuideSo a quick follow up. I’m extremely annoyed with this system. I disconnected the satellite on the first floor and hardwired 2 PlayStations into the second floor satellite. 1 gets over 200mbps down, the other is getting 80. I have multiple smart home devices that I cannot update for. There are 2 rokus on the second floor that have buffering problems. I didn’t spend 1500 bucks to have headaches. I’m ready to return this system and buy the linksys 6e system.
