Dtm316
Dec 26, 2021Guide
axe11000 Device connection issues
hello all. First timer here. I have the orbi axe 11000 with the router and 2 satellites connected. I have a pc and a PlayStation that have connection issues. It seems to be switching between a further...
Dec 30, 2021Guru - Experienced User
There is a new FW update available to try:
Dtm316 wrote:
hello all. First timer here. I have the orbi axe 11000 with the router and 2 satellites connected. I have a pc and a PlayStation that have connection issues. It seems to be switching between a further away satellite and the router. The orbi app currently says it’s not connected but the settings on the ps4 say the signal is 100% and connected to the 5ghz network. The app also show no IP address I also have been having some smart home devices having difficulty. I’m an apple HomeKit user so everything has to be on the same network for it to work properly. I have noticed I have to turn off the 5ghz add the device then reconnect the 5ghz network. Firmware is 6.0.3.68.
