CarterJoshua84
Aug 04, 2022Aspirant
AXE11000 Horrible Speed
Can someone explain to me why I am having these issues. See attached picture for speeds and system set ups. Fiber Modem: Calix Gigacenter: 1gig service. Through local provider" Horry County Tele...
CarterJoshua84
See attached pic. I honestly see no difference in speed with the $1,400 AXE11000 setup vs my 9 month old $699 AX4300 set up.
Maybe I don't get something. I thought with the quad band I would see the same speed over wifi as hardwired. They say you can get up to 10.8 gbps, why can't I get my measly 920mbps LOL
Aug 04, 2022Guru - Experienced User
Ok so you have good wired speeds now over ethernet.
What wireless device are you speed testing with? Brand and model?
You'll not see much over 900Mbps on a 1Gb ISP service and with a 1000Mpbs connected WAN port from the Modem. If your modem supported 2.5Gb on the WAN Port and your ISP supported higher speeds over 1Gb, then you would see speeds over 1Gb on the wire.
- CarterJoshua84Aug 04, 2022Aspirant
- FURRYe38Aug 04, 2022Guru - Experienced User
Ok. If you hold down the OPT key then mouse select the wifi icon on the top tool bar, what connection rate do you see in the wifi configuration list display?
See attached
So that is a connect rate between the device and the Orbi signal only. You'll need to check with Apple on what MIMO antenna support they are using on newer devices. I know my Mac Book pro 2018 I believe is 2x2 which is another limiting factor in regards to bandwidth speeds, depending upon distances from my RBR to the mac, Max I've only seen here is around 700Mpbs.
Most times at a distance I get around 400-500Mbps. And mine only supports AC and max rate of 1300Mpbs.
What I'm getting with a 8 series orbi:
Devices with 4x4 MIMO antenna support can achieve higher speed near 900Mpbs and sometimes over depending. I don't know if newer Mac Books and Mini's have 4x4 support. I know my Mini from 2012 at the time max rate is 450Mpbs and I think was 1x1 antenna configuration.
