ScottinAustin
Apr 29, 2024Aspirant
AXE11000 RBSE960 System receives 400 Bad Request while appying static IP address
I am trying to add some static IP address reservations. In the menu Advanced -> Setup -> LAN Setup, I have added the devices to the list of static IP Address Reservations. When I Click on the APPL...
ScottinAustin
Tried a couple more things.. I deleted the devices I tried to add, and the APPLY still fails with a 400. So, I'm sort of stuck where I can't add, nor delete devices. I will try to reboot (cord pull) each Orbit one at a time. When I logged into one of the Satellites directly, I could not see a menu option to reboot it, just Firmware update and one other option, then logoff.
Apr 29, 2024Guru - Experienced User
Other would be a factory reset and setup from scratch. Possible RBR could be is some bad state on the WEB page. Should clear that out:
